Activity › Forums › Apple Final Cut Pro Legacy › FCP not previewing sound
  • FCP not previewing sound
    Posted by Leon Sarric on March 30, 2010 at 6:16 pm
    Mysterious my FCP has stopped previewing sound.
    When you hit play, it will play at ordinary speed. When you hit fast forward, it used to play the audio clipped at the same time. And when you scrolled frame by frame, the audio would stutter its way through. This has stopped.
    It’s annoying as it’s hard to clip on specific words, as you can’t go frame by frame till you hear the word start. (If I’m making any sense here).
    Leon
    Leon Sarric replied 16 years, 6 months ago 2 Members · 2 Replies
  • Dennis Leppell
    March 30, 2010 at 6:54 pm
    Hit shift+S to enable/disable scrubbing.
    I also like editing using the waveform. Search your manual for how to enable “Show Audio Waveform” to check it out. You may like that method better for precision work.
  • Leon Sarric
    March 30, 2010 at 7:47 pm
    Many thanks for this simple thing!
    Yes, i already use the waveform. I had a freelancer in, who must have accidently hit the shift s and turned it off…
