Activity Forums Apple Final Cut Pro Legacy FCP not capturing miniDV footage taped in LP
  • FCP not capturing miniDV footage taped in LP
    Posted by Cybil Lake on January 13, 2010 at 8:03 pm
    Please HELP! I taped some mini DV in LP mode and my FCP will not capture it.
    The capture window plays the footage but if i hit capture – the capture window doesn’t capture because it is looking for timecode. The timecode does not advance if i try to capture.
    I have fcp 6.
    Cybil Lake replied 16 years, 7 months ago 2 Members · 2 Replies
  • Michael Sacci
    January 13, 2010 at 9:45 pm
    LP is never recommend to record in but if you do, it is recommended that you capture from the camera it was recorded with.
    But if you do a capture now with Device Control set to non-controllable device it will not look for TC.
  • Cybil Lake
    January 14, 2010 at 1:56 am
    thank you.
    But if you do a capture now with Device Control set to non-controllable device it will not look for TC.”
    where is device control? I searched for it but couldnt find it in FCP 6
