Activity Forums Apple Final Cut Pro Legacy FCP net-installatin and serial number
  • FCP net-installatin and serial number
    Posted by Per Ottesen on May 26, 2008 at 9:08 am
    We tried to make a net-installation of FCP, by making a complete installation, then removing the serial number ID, make a disk image to install on several machines.
    When we start FCP the first time, it ask for a serial number and we type the respective serial number (one separate for each machine, it’s comple legal), and the program starts, and it all function perfect.
    After a restart the serial number has been replaced from the original we used to the initial installation, and then it wan’t start, because it’s locked to another Mac.
    How can we prevent the machine to overwrite the “correct typed” serialnumber with the one we used on the “master machine” ??
    Per Ottesen replied 18 years, 3 months ago 2 Members · 2 Replies
  • Kevin Monahan
    May 26, 2008 at 3:37 pm
    I deployed FCS this way when I was working at Deluxe. First, I’d make Disk Images of FCS on an Xsan volume. Then I’d mount each disk from the disk image on each client and install. Then I would enter the serial number. It worked fine.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Per Ottesen
    May 26, 2008 at 7:17 pm
    Thank’s, we will give another try, with a complete new image and new packages (we are using Filewave to this purpose) and then we cross our fingers.
    Great to know that it SHOULD work
