FCP Multiclip Export keeps crashing
I have a 2 camera sequence that I set up to multiclip edit in FCP 7. During the editing process, I encountered some issues with the sequence. At one point in particular there was this really loud noise and the image had all sorts of crazy boxes. I deleted the multiclip and re-digitized the media. This seemed to do the trick. The problem now is that every time I try to export the sequence, either with Compressor or to a QuickTime Conversion, FCP crashes. Does anyone have any ideas on what is going on here? If a full fix isn’t possible, can you think of any quick fixes in the meantime? I’m under a very tight deadline and need to have the posted by the end of the day.
