FCP movie to QuickTime movie
Hi all,
I’m using and can only use a self-contained FCP movie in CinemaCraft (Great mpeg2 encoder) in Windows with the QuickTime label.
In this case it is on an external drive that the Windows machine can also read via MacDrive.Again the crux of the matter is that Windows will not run FCP and hence will not recognize the self-contained FCP movie. (not even via it’s QT reference movie designation-that was a test to see if I could trick it into using the FCP file)
Cinemacraft looks for a QuickTime file only and it must be self-contained.
I have to convert the FCP movie to a self-contained file with the QuickTime label.
To retain it in the exact same properties as the FCP movie I save it back in the QT player, now as a solid self-contained movie with the Quicktime label, which the encoder sees, and works on correctly.
Now this involves a lot of render time and drive space (I use 8-bit un-compressed) so hence my origional question, to save time and space :-
“So apart from saving back the self-contained FCP movie as a QuickTime file,
how can we get that self-containd movie into a Quicktime package without quality loss?”
Is there another quicker way?.Cheers
Alexander
