Activity Forums Apple Final Cut Pro Legacy FCP Log and Transfer Audio Monitoring
  • FCP Log and Transfer Audio Monitoring
    Posted by James Dow on January 18, 2010 at 8:00 pm
    I had to reconfigure my edit setup for a project since I needed to import from a portable drive via Firewire. I unplugged the ioHD box from the Firewire. My audio monitoring is now out of the computer’s line out.
    Can I monitor audio from Log and Transfer via the computer’s line out? I haven’t found the right preference/setting to do this.
    Paul
    JPD
    James Dow replied 16 years, 7 months ago 2 Members · 2 Replies
  • John Fishback
    January 19, 2010 at 8:51 pm
    Sounds like it should work. Just set your sound out in system prefs to line out or internal speakers. Occasionally I have to open up the sound system prefs and reset them. Then it works.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • James Dow
    January 22, 2010 at 2:22 pm
    Thanks John. I had to trash my preferences and everything was then OK.
    When I changed my logging bin the same thing happened again.
    JPD
