Activity Forums Apple Final Cut Pro Legacy FCP Log and Capture w/ older camera
  • FCP Log and Capture w/ older camera
    Posted by Jonathan Poff on September 23, 2007 at 2:43 pm
    Hey-
    So, i am trying to import my 25-30 hours of home video footage, and in an effort to not cause too much wear on my XL2 heads, I decided to use my sony handycam (mini dv, firewire). I went into log and capture, and when i began to play the video to set the I/O points, i got these horizontal lines that were green and purple… I don’t know what is happening! Please help. I really don’t want to have to use my XL2 for this.
    -Jonathan
    Jonathan Poff replied 19 years ago 2 Members · 2 Replies
  • Don Greening
    September 23, 2007 at 4:11 pm
    Hi Jonathan,
    Welcome to the COW. What model of handycam do you have and how old is it? I’ve been using a little Sony DCR-HC30 as a deck for a couple of years now have never seen the types of glitches you’re describing. It sounds almost like a head alignment issue when your Sony is playing back the tapes or the heads need cleaning. At this point it doesn’t sound like a FCP issue.
    It also could be a problem with the FW connection at the camera. Try plugging/unplugging the cable to check for a bad connection.
    For what it’s worth I use my little Sony to capture footage from an XL2, GL2 and a Sony PD170 all the time without a problem.
    – Don
  • Jonathan Poff
    September 24, 2007 at 9:55 pm
    Okay, it looks like it is a DCR-TRV30, and i have tried unplugging, with no luck…
    Thanks for your help!
