Activity Forums Apple Final Cut Pro Legacy FCP keeps crashing
  • FCP keeps crashing
    Posted by Danica Barnes on January 10, 2011 at 11:00 pm
    I’m using FCP 7, and it keeps crashing. I’ve already tried trashing the prefs, and that doesn’t help. My media is stored on an external G-Raid drive, and it is apple pro res 422 quicktimes. I’ve imported a few of these files into my project bin. When I scrub through the clips in the viewer, FCP crashes. What’s happening here? Should I not have my media on this external drive?
    Paul Jay replied 15 years, 8 months ago 4 Members · 4 Replies
  • David Roth weiss
    January 10, 2011 at 11:15 pm
    You definitely want your media on an external drive.
    Close FCP and Fix Permissions on te system drive using the Apple Disk Utility and see if that helps.
    BTW, check “About Final Cut Pro” and let me know what version it says you’re running please.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Danica Barnes
    January 10, 2011 at 11:52 pm
    I went into disk utility and repaired the disk permissions, but this didn’t seem to help. When I went into FCP and tried to scrub through a clip that I had imported, the program crashed again.
    I’m running FCP 7.0.3
  • Bob Auiler
    January 11, 2011 at 12:28 am
    You might have a corrupt project file, a quick check would be to create a new project and see if the media imports and plays in the new project.
    Bob Auiler | bob.auiler@mvpcollaborative.com
  • Paul Jay
    January 11, 2011 at 11:05 pm
    Indeed. Reimport in new project.
    Also. Import media from your system drive.
    too rule out the external drive. How is it formatted?
    Try to create a new admin user. Login with that.
    And see if the problem persists.
    This way you know if it’s a system issue or not.
