Activity › Forums › Apple Final Cut Pro Legacy › FCP is sluggish while editing or saving project
  • FCP is sluggish while editing or saving project
    Posted by Chuck Purnell on May 18, 2011 at 4:17 pm
    I am sure having an issue with FCP 7 being kind of sluggish while editing. I am working on a HD project on my Macbook Pro. Most of the footage I am using is on my 4TB Caldigit HD and I have more footage coming from a Lacie Drive.
    After being burned a few times earlier in editing career, I try to save a project every 2-5 minutes. Now I am noticing that everytime I go to save, I am getting the beach ball spinning or just takes longer than normal to save so I can get back to editing!
    This same thing sometimes happens when I am working with Motion too. Lesson learned from working with Motion is making sure I don’t have any other programs running when Motion is open. That seemed to help and so I do the same with FCP. Nothing is open. Other things I have tried is to save my work then close FCP and then completely shut down my computer for a few minutes then bring it back up and usually that will fix the issue.
    Anybody know why this is? My RAM is maxxed out in my laptop. A friend of mine asked me if I ran disk utilities on the drives yet and I said I hadn’t. Is this something i need to do and is this where I would click Verify disk or repair disk or something like that? Would I run that on my capture drives?
    Another thing I am noticing is that when playing back some of the video clips, it freezes for a quick hit then continues playing. I haven’t figured out what is causing those little hiccups to happen either. When I pause the playhead and re play the video over that same section, sometimes I hit the hiccup again and sometimes it plays back just fine. Strange huh?
    Cre8tive Minds Entertainment, LLC
    Ken Jones replied 15 years, 4 months ago 2 Members · 3 Replies
  • Chuck Purnell
    May 18, 2011 at 4:35 pm
    Not sure if this has anything to do with it or causing to my sync issues is that i am editing footage from a 2 camera shoot. Not using multiclip. I am manually cutting between the 2 cameras. I noticed that one of the camera’s clips from a Panasonic HVX200 has a size of 1280×1080 and the other camera was a Canon XHA-1 and those clips were 1440×1080. Before starting the editing, I set up my sequence to edit 1440×1080 Matrox MXO2 Apple ProRes (LT). I just rebooted my computer and opened my sequence settings and was surprised that it has been changed to 1280×1080 and the Compressor set to DVCPRO HD 1080i60.
    Does any of this make any sense as to why I am dealing with the issues I spoke about earlier? I already have 40 minutes worth of cut footage on my timeline. Should I just keep the sequence like it is or should I manually change it back to how I had it? I am the only person that uses my computer so nobody else could have switched the settings.
  • Chuck Purnell
    May 18, 2011 at 11:35 pm
    I was considering doing that. Thanks!
  • Ken Jones
    May 19, 2011 at 2:57 am
    Did you install the ProKit update? I started having these same issues immediately after the update. I first noticed the spinning beach ball in Compressor, but have also had the same video playback problems you are experiencing.
