Activity Forums Apple Final Cut Pro Legacy FCP imac to tv output
  • FCP imac to tv output
    Posted by Krista Lettko on February 4, 2010 at 2:40 am
    I am updating my editing station, and am looking to add a lcd hdtv to view my FCP projects from my imac, and to do color correction. I need to know whether or not I need a breaker box to do so. I have been told that the video quality will be the same without a breaker box, I have also been told that I don’t need a breaker box, and it will work without it. I don’t want to purchase a new tv without knowing for sure whether I will need the box. If I do need it, I will purchase another monitor and make my station dual monitor instead. I need some input.
    HELP.
    Sarab Lubana replied 15 years, 12 months ago 4 Members · 4 Replies
  • Chris Tompkins
    February 4, 2010 at 1:26 pm
    What do you as an output from the imac?
    Do you want to run Firewire out to a deck/camera and then to a monitor?
    How our you getting video in and out of the imac now?
    Chris Tompkins
    Video Atlanta
  • Alan Okey
    February 4, 2010 at 1:47 pm
    If you are editing HD video and you want accurate color representation, you will need a breakout box like this:
    https://www.matrox.com/video/en/products/mxo/
    Simply using a second computer monitor attached directly to the computer (i.e. as a second computer monitor) will not give you accurate color preview for video content. You need a proper video output interface and a way to properly calibrate the preview monitor.
    If you are not editing HD, you can use Firewire out of your iMac through your camera or DV deck to connect to a TV. Alternately, you can use a DV interface like the Canopus ADVC-110:
    https://www.grassvalley.com/products/advc110
    The Canopus is actually preferable to a deck or camera because most consumer DV devices (cameras and decks) do not output the proper black level for US-NTSC, which is 7.5 IRE. Instead, they mostly output 0 IRE, which is too dark. If you do color correction while viewing improper black levels on your preview monitor, this will result in your videos appearing washed out when you burn a DVD or play back your video on a properly calibrated system.
    More info here:
    https://www.signvideo.com/dv-black-levels-dvd-authoring-mpeg-2-part-1.htm
  • Krista Lettko
    February 4, 2010 at 4:39 pm
    Thank you thank you thank you. I am still new to this wonderful world of editing, and this is exactly the information I was needed. Thank you!
  • Sarab Lubana
    September 10, 2010 at 9:36 am
    I Have Sony Mini DV Cam. But I dont know how to get preview on TV with Firewire?? I Have Mac Pro G5 With Final Cut Studio-2. PLzz help me … 🙂 Thanx in advance …. 🙂
