Activity Forums Apple Final Cut Pro Legacy FCP HD playback slow to start/stutters
  • FCP HD playback slow to start/stutters
    Posted by Jacqueline Nauman on November 11, 2010 at 7:19 pm
    I am subtitling a clip that is an HD imported QT clip. I have all the latest codecs and whenever I play NTSC video I do not have this problem. With the HD clips, whether they are from the cf card or an imported quicktime, when I play this clip it takes several seconds to start (whirligig thingy twirls for 5 – 10 secs) and often stutters thru the playback. I have unchecked the warning for dropped frames and checked my disc space. I am new to HD, so please bare with me. I am including screen shots of the pertinent settings….at least I think they are pertinent. If anyone can please tell me where I might have a wrong setting or what else I should look for? Subtitling is tedious enough without this slowing me down! This system should work fine with HD!
    Thanks for your much needed help!
    Jacquie
    System info
    USER PREFS – General
    USER PREFS – Memory & Cache
    USER PREFS – Render Control
    SYSTEM SETTINGS – Scratch Disks
    SYSTEM SETTINGS – Playback Control
    SYSTEM SETTINGS – Memory Cache
    MAC: 2 x 2.8 Quad Core Intel Xeon
    Memory: 2GB 800 MHZ DDR2 FB-DIMM
    OS: Mac OS X 10.6.4
    Final Cut Pro 6.0.6
    Zak Ray replied 15 years, 10 months ago 4 Members · 19 Replies
  • 19 Replies
  • Zak Ray
    November 11, 2010 at 8:04 pm
    CF card? Are we talking about a DSLR here? Did you transcode the footage properly through Log and Transfer, or take it straight from the card in it’s native format?
  • Jacqueline Nauman
    November 11, 2010 at 8:22 pm
    I should’ve been clearer. This also happens with footage pulled from a CF card….yes, that has been imported with log and transfer….but in this case it is a Quicktime movie that was sent from the client.
    OS: Mac OS X 10.6.4
    Final Cut Pro 6.0.6
  • Zak Ray
    November 11, 2010 at 8:28 pm
    This is an MPEG-2 file. You can’t work natively with this. Convert it to ProRes.
  • Jacqueline Nauman
    November 11, 2010 at 8:49 pm
    I see. Ok. Am using Mpeg Streamclip to convert it now. Will see how that does. Thanks!
    OS: Mac OS X 10.6.4
    Final Cut Pro 6.0.6
  • Jacqueline Nauman
    November 11, 2010 at 9:42 pm
    Yep. Much better. Still has to think a second but much better. It plays thru and I can easily step thru the clip. This is what my converted file became.
    Thanks much!
    OS: Mac OS X 10.6.4
    Final Cut Pro 6.0.6
  • Jacqueline Nauman
    November 11, 2010 at 10:43 pm
    Ok much better playing thru the sequence but it still takes a few seconds to start playing. If I play it from the Canvas play button it thinks a few secs then stops after playing a frame or two. If I play it from the timeline or the keyboard the whirly gig spins for up to 10 secs. What can I do to make it start more instantaneous?
    OS: Mac OS X 10.6.4
    Final Cut Pro 6.0.6
  • Joey Burnham
    November 11, 2010 at 11:19 pm
    You don’t need prores HQ. Just try regular prores. HQ is really only for frame sizes bigger than 2k.
    Try it out and see if that makes a difference. At least it will cut down on file size and bandwidth.
    Joey
  • Zak Ray
    November 11, 2010 at 11:25 pm
    I wouldn’t say that HQ is just for large resolutions, but yes, you can probably use regular ProRes for your purposes.
    Also: where are you storing your media?
  • Jacqueline Nauman
    November 11, 2010 at 11:32 pm
    ok. Converting again without HQ.
    The project is on my external 2TB firewire drive which has more than 1 TB available. However, the converted clip was saved to my main drive.
    Original footage is on the external.
    OS: Mac OS X 10.6.4
    Final Cut Pro 6.0.6
  • Joey Burnham
    November 11, 2010 at 11:33 pm
    Are you able to run a speed test on that external? Might be as simple as the drive isn’t fast enough to keep up with HD. How is it connected?
    Joey
