Activity › Forums › Apple Final Cut Pro Legacy › FCP HD playback slow to start/stutters
Zak Ray replied 15 years, 10 months ago 4 Members · 19 Replies
Jacqueline Nauman
November 11, 2010 at 11:38 pmFirewire 800. RPM is 7200
MAC: 2 x 2.8 Quad Core Intel Xeon
Memory: 2GB 800 MHZ DDR2 FB-DIMM
OS: Mac OS X 10.6.4Final Cut Pro 6.0.6
Zak Ray
November 11, 2010 at 11:42 pmShould be enough for regular ProRes… I assume your sequence settings are also correct?
Joey Burnham
November 11, 2010 at 11:43 pmYeah you should be okay. Have you run the regular drill of trashing prefs, rebooting in safe, repair disk permissions, etc?
Joey -
Jacqueline Nauman
November 12, 2010 at 12:24 amYup. Did all that.
Jacqueline Nauman
November 12, 2010 at 12:28 amI think seq settings are correct but I had to step away for while so can’t look at the moment.
Walter Biscardi
November 12, 2010 at 12:42 am[Zak Ray] “I wouldn’t say that HQ is just for large resolutions, but yes, you can probably use regular ProRes for your purposes.”
Yes, ProRes HQ was designed for frame sizes larger than 1080. This has been discussed numerous times on this forum.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
Walter Biscardi
November 12, 2010 at 12:44 am[Jacquie Nauman] “The project is on my external 2TB firewire drive which has more than 1 TB available. However, the converted clip was saved to my main drive.
Original footage is on the external.”All of the footage has to be on your external drive. NEVER put any media on your main System Drive.
Zak Ray
November 12, 2010 at 12:50 amI was under the impression it was also for particularly high-quality sources– a film telecine or HDCAM transfer, for example– even if the frame size was only 1080.
