Activity › Forums › Apple Final Cut Pro Legacy › FCP HD Filling up G-Raid completely and crashing on capture
  • FCP HD Filling up G-Raid completely and crashing on capture
    Posted by Alex Bond on June 16, 2008 at 7:36 pm
    Ok,
    Apologies to those who have already tried to help me with this issue but I still can’t fix it.
    I am running the first version of FCP HD on a Dual 2gb G5, capturing Analogue video through an ADVC110 Firewire unit.
    Every time I try to capture the G-Raid fills up completely and the the FCP itself crashes. The only way to fix the machine is to reboot it and delete the massive Scratch Cache created on the external drive.
    I have tried:
    correct easy setup
    limiting the total time of captured clips
    limiting the total size of captured clips
    Can anyone help??
    Alex
    Alex Bond replied 18 years, 3 months ago 3 Members · 3 Replies
  • Shane Ross
    June 16, 2008 at 9:35 pm
    #10 – Capture now makes large file, Beachball
    Shane’s Stock Answer #10: Capture now makes large file, cursor becomes a spinning beachball
    ISSUE: ALLOCATING DISKSPACE
    1) Set a limit on Capture Now. Set it to 60 min if you want the whole tape.
    2) Deactivate any anti-virus/file saver software, including Norton and Virex. For some reason these programs think that the large files created when you capture media are in fact caused by some sort of virus, and they try to prevent this.
    3) Do not capture to your main system drive. While this works for some, it doesn’t for many and really is not the best way to capture and store your footage. Get a good external hard drive. Firewire or eSATA are good options.
    4) Check the format of the drive you are capturing to. Typically if you buy a hard drive that is pre-formatted, it is formatted as FAT32, a PC format. For best results it should be formatted Mas OS Extended, journaling off. If it isn’t, copy your files from it and re-initialize it. If it is any other format, you will encounter problems. If not at first, then eventually.
    Shane
  • Steve Eisen
    June 16, 2008 at 9:46 pm
    If possible, capture your analog video onto dv then capture your dv via firewire.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Alex Bond
    June 17, 2008 at 6:23 pm
    thanks for the info but i have tried all those things 🙁
