Activity › Forums › Apple Final Cut Pro Legacy › FCP HAS TOTALLY WIGGED OUT
  • FCP HAS TOTALLY WIGGED OUT
    Posted by Tony Pierce on January 28, 2006 at 3:05 am
    Dig this: First, I hooked up camera and log and capture sees it as “ok,” I can control it — but it gets no picture; then I do a restart and my left monitor is black; FCP is showing up on the right monitor, but you can’t use it. Running version 4.5 with Tiger 10.4.4 (recently installed it but have used FCP since) on a G5 dual 2.5. What the heck is going on? Twilight zone?
    Tony Pierce replied 20 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Matthew Brunn
    January 28, 2006 at 4:26 am
    Did you install OSX the right way? Wipe Harddrive>Install OSX>Install FCP and other pro apps?
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.9
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Captain Mench
    January 28, 2006 at 5:19 am
    Hang on Matthew —
    Let’s not get drastic just yet. But Tony — do save his post for later.
    Try this…
    Go into System Drive/Library/Receipts
    Then look for QuickTime###.pkg where the ### is 702 or 649 or whatever.
    Grab ALL of those… even one that might say 704.
    Trashem
    Go to your Apple menu and select Software Update.
    Run the QT update again.
    You should be fine.
    CaptM
  • Jeremy Garchow
    January 28, 2006 at 8:13 pm
    Here’s the pictures to go with Capn’s words:
    https://docs.info.apple.com/article.html?artnum=301852
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Tony Pierce
    January 29, 2006 at 5:13 pm
    Thanks for the suggestion, but I do not see a folder called “receipts”. Am I confused?
  • Jeremy Garchow
    January 29, 2006 at 7:35 pm
    Look at the link i provided. It even has pictures.
  • Tony Pierce
    January 29, 2006 at 9:05 pm
    No luck with QT trashing. Guess I will try to to reinstall FCP.
  • Tony Pierce
    January 30, 2006 at 12:16 am
    So I am curious about your suggestion — no, I saw no such direction about wiping the drive clean before installing. Is that a must? Is that in the directions with Tiger? Surely not.
