Activity Forums Apple Final Cut Pro Legacy FCP failing to reconnect meida it recognizes
  • FCP failing to reconnect meida it recognizes
    Posted by Shawna Talbot on May 8, 2012 at 8:58 pm
    Working as an AE on a small doc and someone removed one letter from a clip name by mistake. FCP saw that the file went “offline”. When we’ve tried to reconnect to that file FCP accepts it as the timecode is all the same, but when we click: reconnect it does not reconnect. It stays offline.
    Adding the letter back, restarting everything, and opening an autosave does not seem to fix this problem. Any suggestions?
    Shawna Talbot replied 14 years, 4 months ago 1 Member · 1 Reply
