Activity Forums Apple Final Cut Pro Legacy FCP EXporting to DVDSTUDIO 4 Pls Clarify – Confused
  • FCP EXporting to DVDSTUDIO 4 Pls Clarify – Confused
    Posted by Michelle Lewishon on July 24, 2007 at 3:09 pm
    ‘m sure this topic has been convered. But I still don;t have a striaght answer
    I have shot in 24p
    1 – I’m capturing the footage using easy setup DV-NTSC 23.98
    2 – Using sequence set-up
    Safe RT Pull-Down Pattern 2:3:2:3
    **** assuming what I’m doing above is correct This is what I’m confused about —
    3 – What is the best method of exporting to dvdstudiopro?
    a – Can I just do a Export Quicktime movie – Using the current settings?
    4 – What is the ebst method of exporting my footage in to DVDSTUDIO-PRO4
    Michelle Lewishon replied 19 years, 1 month ago 3 Members · 4 Replies
  • Tom Wolsky
    July 24, 2007 at 3:50 pm
    What camera shot this? Exactly what settings were used on the camera?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Michael Sacci
    July 24, 2007 at 5:43 pm
    The question is what is the sequence framerate as well as the clips captured framerate? 23.98? If yes to both,
    the best quality encodes will always be exporting the timeline to compressor. Make sure the frame rate is 24P and then field domin. is grayed out.
    I always recommend the highest CBR bitrate that will fit on the DVD. (Audio is always encoded in ac3 at 192)
    If your video is good quality your encode will be good. (Unless you are trying to get 3 hours onto a DVD-5)
  • Michelle Lewishon
    July 24, 2007 at 7:29 pm
    Hi
    thanks for your reply
    I used dvx100b
    scene 5 I believe it is .. But shot in 24p not the advanced mood.
    But the regualar 24p format
    Michelle
  • Michelle Lewishon
    July 24, 2007 at 7:40 pm
    Thanks for your reply,
    So you are stating that using export – quicktime and then taking it into the dvdstudio pro 4 and have it compressed there is not as good as using the compresser? ???
    Doesn’t DVDstudiopro 4 comrpessess the exported file even after the file is compressed via compressor? Or am I wrong?
    To capture the footage I used dvx100b camera. I used scene 5 preset on camera which is 24p (Not the advanced mood in the dvx100b camera)
    As for your other questions. I will post another .. to see if I can find that information.
    I shall post in in couple of hrs. I’m not in front of my editing computer.
    Cheers
