Activity Forums Apple Final Cut Pro Legacy fcp export to dv stream adds 5 minutes to file
  • Shane Ross
    February 4, 2008 at 8:24 pm
    Have you looked at the resulting file? Is there footage in there that is not in the sequence?
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Jodie Baltazar
    February 4, 2008 at 8:54 pm
    yes. It’s strange. The DV Stream is 5 minutes longer than the sequence.
    HOWEVER, I did just export it without changing the name of the sequence (when saving the file) and the DV stream was outputted correctly.
    Before, I changed the filename on export. (saved the .dv file with a different name than the sequence)
    Odd, but working.
