Activity Forums Apple Final Cut Pro Legacy FCP DV out only plays still and sound to GL2…??
  • FCP DV out only plays still and sound to GL2…??
    Posted by Stu Aull on September 10, 2005 at 8:45 am
    Hi Folk-
    -Beta SP component -recorded via blackmagic design-carded G5 mac,
    -Media Managed thru FCP 4.5 to DV format (I think. It certainly reduced the file size).
    -Set the FCP A/V Settings menu to “Apple DV”
    -GL2 says “DV IN” in finder, and a FreezeFrame off the FCP timeline is displayed in the camera, along with the timeline sound, but no moving images
    -tried “View”>”Refresh AV Devices” – nothing
    -tried “View”> “Devices” >”external Video”>”All Frames” – still nothing
    suggestions??
    thanks!
    Stu Aull
    Alaska
    Stu Aull replied 20 years, 12 months ago 3 Members · 3 Replies
  • Shane Ross
    September 10, 2005 at 10:38 am
    [stu Aull] “Media Managed thru FCP 4.5 to DV format (I think. It certainly reduced the file size)”
    That is the most likely culprit. It might well NOT be in the DV format. Check the Item Properties…
  • Rob Forsythe
    September 11, 2005 at 4:21 am
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    If working this list doesn’t cure the problem… you may have a PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    14. Important: Quit FCP, then Restart FCP.
    15. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Stu Aull
    September 12, 2005 at 8:16 pm
    Rob! Wow! thanks- will try these ideas
    kind regards
    Stu Aull
    Alaska
