Activity › Forums › Apple Final Cut Pro Legacy › FCP Does Not Recognize FX1 Firewire Connection
  • FCP Does Not Recognize FX1 Firewire Connection
    Posted by Ron.bluecoast on September 30, 2006 at 5:13 pm
    Although the system has worked fine in the past, FCP is not recognizing my FX1 connected to my G5 Tower via firewire. Also, if the camera is turned off, FCP works fine…but as soon as the camera is turned on, I get the “spinning color wheel” in FCP and it acts like it is frozen.
    I have checked settings and disconnected and then re-connected the external drive and the FX1 firewire connection to the G5 Tower. Nothing.
    Any ideas? I can’t import.
    Tom Wolsky replied 20 years ago 3 Members · 7 Replies
  • 7 Replies
  • Ron.bluecoast
    September 30, 2006 at 5:44 pm
    I have FCP 5.0.4
  • Tom Wolsky
    September 30, 2006 at 5:55 pm
    Full specs on your system, deck, drives, how everything’s connected, settings on deck and settings in FCP would be helpful.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Ron.bluecoast
    September 30, 2006 at 6:10 pm
    Tom,
    Thanks for responding.
    I have OS X 10.4.8
    PowerPC G5 w/ dual 2 GHz
    1 GB ram
    FCP 5.0.4
    Deck is the Sony FX1 – HDV to DV
    Using a Lacie 160 GB external drive connected to G5
    FX1/Deck Settings:
    VCR HDV/DV HDV
    COMPONENT 1080i/480i
    iLINK CONV ON (HDV to DV)
    TV TYPE 16 X 9
    A/V to DV OUT OFF
    FCP Settings:
    Easy Setup: DV Anamorphic
    Hope this info is what you were looking for.
    Ron
  • Tom Wolsky
    September 30, 2006 at 6:39 pm
    Don’t plug in the camera while the application is running. Quit the app, start the camera, launch the app. Doesn’t the camera need to be in DV mode if you’re downconverting? Try daisychaining through the drive or removing the drive. I’m assuming it not on a separate card.
    All the best,
    Tom
  • Ron.bluecoast
    September 30, 2006 at 6:52 pm
    I tried starting up FCP and then plugging in the camera/deck. Nothing.
    I had removed the external drive…no effect.
    The camera is set to downconvert from HDV to DV and it does so.
    Still stumped.
  • Christopher Wright
    September 30, 2006 at 7:31 pm
    One of my clients had this problem and they had to go into the Receipts folder and get rid of all but the lastest Quicktime receipt. That fixed the problem.
  • Tom Wolsky
    September 30, 2006 at 8:30 pm
    No. The other way around. Camera first plugged in and correct. Trash your preferences. Start FCP set DV NTSC Anamorphic.
    All the best,
    Tom
