Activity Forums Apple Final Cut Pro Legacy FCP Device Control of JVC GY-HD250
  • FCP Device Control of JVC GY-HD250
    Posted by Tocha on August 27, 2007 at 11:19 am
    I have connected the HD SDI output of the camera (1080i50) to my decklink board and I have image and timecode on the capture window of Final Cut Pro.
    But I am not able to have the Device Control from FCP, the best I can do until now it use the “DVCPRO HD FireWire 25fps” it shows VTR OK just for a few seconds, and during that time I am able to control the camera, after that few seconds it shows No Communication
    If I switch the Easy Setup in FCP to 720p25 I am able to control the camera, but I am not able to digitize using my Blackmagic board.
    Is there a way to control and digitize from the camera using the HD-SDI output and Firewire for Device Control?
    I am trying to use this setup for several reasons:
    1 – Final Cut when digitizing from JVC Decks or cameras in firewire doesn’t capture the complete footage (make holes of 7 seconds in the beginning of each filmed clip, sometime in the midle)
    2 – Final Cut doesn’t have support for 720p50, so using the camera built in capability of converting to 1080i50. I will be able to edit this material in Final Cut.
    Jo
    Mike Simpson replied 19 years ago 2 Members · 1 Reply
  • Mike Simpson
    September 5, 2007 at 2:48 pm
    check this out for the 720P50 workflow in FCP:
    https://www.aulich-adamski.de/en/perm/720p50-capturing-editing-in-final-cut-pro
    If that helps maybe you can help me out.
    I have a JVC BR-HD50 that i can’t get RS422 control over seemingly no matter what i tell FCP it is controlling. I haven’t used it in Firewire mode yet because i don’t want to do that!
    I know the deck works as i have tried it with other edit suites and the Kona we have here works with all other decks.
    Any thoughts?
