Activity Forums JVC Cameras FCP Device Control of JVC GY-HD250
  • FCP Device Control of JVC GY-HD250
    Posted by Tocha on August 24, 2007 at 4:52 pm
    I have connected the HD SDI output of the camera (1080i50) to my decklink board and I have image and timecode on the capture window of Final Cut Pro.
    But I am not able to have the Device Control from FCP, the best I can do until now it use the “DVCPRO HD FireWire 25fps” it shows VTR OK just for a few seconds, and during that time I am able to control the camera, after that few seconds it shows No Communication
    If I switch the Easy Setup in FCP to 720p25 I am able to control the camera, but I am not able to digitize using my Blackmagic board.
    Is there a way to control and digitize from the camera using the HD-SDI output and Firewire for Device Control?
    I am trying to use this setup for several reasons:
    1 – Final Cut when digitizing from JVC Decks or cameras in firewire doesn’t capture the complete footage (make holes of 7 seconds in the beginning of each filmed clip, sometime in the midle)
    2 – Final Cut doesn’t have support for 720p50, so using the camera built in capability of converting to 1080i50. I will be able to edit this material in Final Cut.
    Jo
    Tocha replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
