Activity › Forums › Apple Final Cut Pro Legacy › FCP crashing! in DVCPRO 720-24p with AJ-HD1200A deck
Posted by Dpray on May 17, 2006 at 4:26 amI love the Varicam, but capturing footage into FCP from the Panasonic AJ-HD1200A deck has never been smooth. During the last year I’ve brought in at least 100 hours of footage successfully, but with a fair amount of issues… lots of rebooting to get clips to actually capture on the 2nd try, lots of checking settings, the usual BS associated with occasional TC drops and end-of-tape stuff. Never as easy as DV ftg.
I’ve got 50 new tapes to capture and now something’s really wrong. Whenever there is questionable footage on the 1200 deck, or at other random times, I’m seeing an E-2 error message on the deck and Final Cut Pro is completely crashing. I’ve done multiple troubleshooting tests and it’s driving me nuts. It’s not my G5 system (OS X 10.4.4) it’s not my FCP (5.0.4)– because I’ve tried the deck on a friend’s G4 w/same software– same exact FCP crash. Also, this is the same system that has worked before with the same footage (and same varicam settings on all the tapes)
FCP is crashing during capture AND when playing footage– at seemingly random times. I’ve successfully captured in areas where it previously crashed or gave errors.
Any ideas? thank you.
dpray
Gary Adcock replied 20 years, 3 months ago 6 Members · 9 Replies -
Jeremy Garchow
May 17, 2006 at 5:43 amIf that same deck is crashing two computers, what do you think the common denominator is? Have you had the deck checked?
Jeremy
Jan Crittenden livingston
May 17, 2006 at 10:04 amMy first thoughts were that perhaps the Deck could use a little cleaning. Don’t know where you are located, but if you have a lot of humitidy or dust, the machine may have collected enough crud to throw off the ability to read TC and thus cause some problems. It can also happen with a questionable bit of tape that has been exposed to an extremem in weather and not yet re aclimated.
But all of the crashing on the computer takes a toll as well, at least it does on my PC and so it might stand for a bit of clean up as well.
Hope this helps,
Jan
Jan Crittenden Livingston
Product Manager, DVCPRO, DVCPRO50, AG-DVX100
Panasonic Broadcast & TV Systems -
Gary Adcock
May 17, 2006 at 12:07 pm[dpray] ” lots of rebooting to get clips to actually capture on the 2nd try, lots of checking settings, the usual BS associated with occasional TC drops and end-of-tape stuff. Never as easy as DV ftg.”
Something is not correct, except when running beta software, I have never had any of these issues. Capturing from the 1200a has always been as easy as working in DV. (except in 720p50) Time code Drops and end of tape issues are related to how you work– not whether the deck is functioning properly.
[dpray] “Whenever there is questionable footage on the 1200 deck, or at other random times, I’m seeing an E-2 error message on the deck and Final Cut Pro is completely crashing” Questionable footage??? Speed ramping, capturing bars and tone laid on tape, rewind the tape in camera for preview all can effect how the TC ins laid and therefore capture.
[dpray] “It’s not my G5 system (OS X 10.4.4) it’s not my FCP (5.0.4)– because I’ve tried the deck on a friend’s G4 w/same software– same exact FCP crash. Also, “ HHHMMMM!!! I’m with Jeremy on this one.
[dpray] “Also, this is the same system that has worked before with the same footage (and same varicam settings on all the tapes)”
The EXACT same tapes? one you have digitized in a prior session? then you know what you need to do.Bothered checkin the hours on the deck?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Chicago, IL
gary@studio37.com -
Dpray
May 17, 2006 at 1:28 pmThank you Jeremy, Jan and Gary for responding to this. Logically, I agree it’s the deck. The deck rental house insists that it just came back from the factory and they’ve had no problems with it. I keep wondering if it’s the fact that I’m on OS X 10.4.3– have you heard whether or not that might be a bad thing? (the other G4 I tested on was running that, too)
And to answer your question, no my capturing sessions from December and September were not the exact same tapes, but they were from the same camera, same settings, etc. this is all one project and we’ve been duplicating everything all along). Finally– for the record– I never rewind tapes in the field, nor do I allow full shut downs. Battery changes are the only “known” possible TC hits, and don’t always create a bump.
doug
Walter Biscardi
May 17, 2006 at 3:13 pm[gary adcock] “Something is not correct, except when running beta software, I have never had any of these issues. Capturing from the 1200a has always been as easy as working in DV. (except in 720p50) Time code Drops and end of tape issues are related to how you work– not whether the deck is functioning properly.”
I’ll second that. We’ve had our 1200A for over a year and it’s no different than capturing our Beta or DV footage. Something in the setup is defintely wrong on the FCP end I would think.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Walter Biscardi
May 17, 2006 at 3:15 pm[dpray] “I’m on OS X 10.4.3– have you heard whether or not that might be a bad thing? (the other G4 I tested on was running that, too)”
Why haven’t you updated?
Chris Wyatt
May 17, 2006 at 3:50 pmHi Gary and Walter this is a slightly sideways issue but still related to this thread.
I am about to install a suite based on a Kona 3, G5 Quad with 6Gb of RAM and FCP 5.1 for
editing up to 40 hours of DVCPRO HD from Panasonic Varicam shot at 720p | 50 so the threadline“Capturing from the 1200a has always been as easy as working in DV. (except in 720p50)”
is very scary for me.
Could you please help by explaining what the capture problem is from this deck to FCP 5.0 or above?
Thanks in advance.
Dpray
May 17, 2006 at 7:01 pmApparently it was the deck. After the “Error 02” message continued to show on the AJ-HD1200A, even when put onto my other editor’s G5 (the 3rd system I’d checked), it became obvious. I returned it to the rental house, got a replacement, and everything seems to be fine so far, several tapes into capturing. The other clue was that the little green “720p” light had never shown on the first deck. No big deal except for the 8 hours of downtime and troubleshooting… alas, such is post.
I still think the 1200-FCP relationship is more touchy than when capturing DV or from other decks, but this is probably due to the fact that my footage is all run-and-gun, handheld style, from tape insert to eject. It’s a luxury if I can run bars and tone at the top of a tape. Capture-sensitivity is the price I pay.
And for anyone thinking otherwise, I still think the varicam-FCP-720HD “tapeless post” is by far the best way to go for documentaries. I’ve used film, DVX, Sony900 1080i, HDV, DVcam, you name it– the Varicam footage is gorgeous, the camera is superb, and I now have over a hundred hours of full res footage sitting on this little tower by my G5 (8 x 400gig drives). That’s my online.
Thanks for the previous advice about capturing.
doug
Gary Adcock
May 17, 2006 at 9:28 pm[footagehead] “Could you please help by explaining what the capture problem is from this deck to FCP 5.0 or above?”
720p25/50 is not a supported format in FCP. It became an accepted standard in the EU late last summer.
You can use the Kona 3 card- take the Kona 3 720p24 varicam easy setup and change ALL of the 24fps info to 25 save as a new setup and work.
gary adcock
Studio37
Chicago, IL
gary@studio37.com
