Activity Forums Apple Final Cut Pro Legacy FCP crash when opening Boris RED
  • FCP crash when opening Boris RED
    Posted by Chris Paul on August 5, 2005 at 5:09 pm
    Since upgrading to FCP5 my Boris RED plugin has become unstable. The most common problem is FCP quitting when opening a title previously created in RED static. This happens about half the time. I have deleted and reinstalled RED and deleted it’s preferences. I have removed all bad fonts. The crashing does not happen with motion graphics created in the RED generator, using RED as a filter, or using RED as a stand-alone. The Boris Calligraphy plugin is stable but RED has a lot more features. has anyone else encountered ths?
    Chris Paul
    POV
    Chris Paul replied 21 years, 1 month ago 3 Members · 4 Replies
  • Lee Burrows
    August 5, 2005 at 6:56 pm
    Hey Chris. Try reinstalling FCP. That might hopefully clear up your problem.
    Good Luck
    Shouldn’t you be located in DC with the rest of the USPS staff?
    G5 Mac OS X
    Dual 2.0 Ghz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G4 Mac OS X
    Dual 1.25 Ghz
    FCP 4.5 HD
    Lacie Drives 200 Gbs
  • Dave Jenkins
    August 6, 2005 at 5:42 am
    This is a known bug in Red. We found it when creating a custom dual screen layout.
    What layout are you using? Try using the 2 up or 4 up stock layouts that comes with FCP and see if you have the same problem. It’s when you change the layout that things get weird.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Chris Paul
    August 8, 2005 at 3:52 pm
    Wow! You are absoulutely correct. This should have occured to me as my window layout kept reverting to a stock layout after crashes. I will but Boris to see if they will fix this soon. Thanks for the help!
    Chris Paul
    POV
  • Chris Paul
    August 8, 2005 at 5:57 pm
    Whoops- spoke too soon. After heavy use FCP is crashing when opening Boris RED titles even when using standard window layouts. If you have any more ideas I’d be happy to hear them.
    Chris Paul
    POV
