Activity › Forums › Apple Final Cut Pro Legacy › FCP-Compressor help
  • FCP-Compressor help
    Posted by Dan Herz on March 4, 2009 at 5:48 am
    I am compressing a 10 minute 16:9 1080-60i video using compressor. I created a custom setting for the compression. I pasted the summery of the settings below. The issue is that it is taking forever to compress. It has been working for over 1.5 hours and it’s still not finished. Anyone know why it is taking so long? Most of my compressions take a matter of minutes…sometimes 1/2 hour, but never this long.
    I am exporting directly from FCP to compressor with settings below. would it be faster to first export to a QT movie and then compress?
    Any help would be appreciated.
    thanks
    Description: H.264 for high-bandwidth connections
    File Extension: mov
    Estimated file size: 47.6 MB
    Audio Encoder
    AAC, Stereo (L R), 48.000 kHz
    Video Encoder
    Format: QT
    Width: 480
    Height: 270
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 29.97
    Frame Controls On:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Fast (Line Averaging)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Same as Source
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 50
    Key frame interval: 150
    Temporal quality: 50
    Min. temporal quality: 50
    Average data rate: 0.688 (Mbps)
    Fast Start: on
    Jeremy Garchow replied 17 years, 7 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    March 4, 2009 at 5:54 am
    [Dan Herz] “would it be faster to first export to a QT movie and then compress? “
    Yes. what kind of computer?
  • Dan Herz
    March 4, 2009 at 6:17 am
    It is a Macbook pro
    Model Name: MacBook Pro 17″
    Processor Name: Intel Core 2 Duo
    Processor Speed: 2.33 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 4 MB
    Memory: 3 GB
    Bus Speed: 667 MHz
  • Jeremy Garchow
    March 4, 2009 at 6:23 am
    OK. Try exporting first. Then bring that to Compressor.
