Activity › Forums › Apple Final Cut Pro Legacy › FCP Color, image in Scopes window is way too dark…….
Posted by Bill Hanson on April 27, 2011 at 7:26 pmThe subject in the clip that’s displayed in the upper left corner (or top of the Scopes window) is barely visible, as if the settings are way off. Can’t figure out what I did wrong to get this result.
Any feedback would be greatly appreciated.
Cheers,
Bh
Westley Gathright replied 14 years ago 5 Members · 11 Replies -
Shane Ross
April 27, 2011 at 7:43 pmYeah…don’t use the image in the Color Scopes area as ANY sort of reference as to the look and quality of your video. It is VERY FAR from color accurate.
Do use Color you really need a capture/output device and at least an HDTV
Shane
Read my blog, Little Frog in High Def -
Bill Hanson
April 27, 2011 at 8:04 pmYeah, I’m outputting the image from my Mac Pro to an HDTV, so the Color windowing is all displayed on that. The image is not even visible (per the attached screen shot I posted) in the upper left of the screen while in the “Secondaries” tab within the Color interface, I have to see something, right??
Shane Ross
April 27, 2011 at 9:34 pmHow are you getting the signal from your computer to the TV?
Shane
Michael Gissing
April 27, 2011 at 10:53 pmDidn’t see a link in the original post. If you are not seeing the image in the secondaries room then it is difficult to set HSL keys etc. But what you seem to describe is the image above the scopes to the left, which I almost never look at.
Are you using two display monitors and are they the same size. Is your graphics card ATI or NVIDIA? Does it always happen so a restart doesn’t fix it?
Bill Hanson
April 28, 2011 at 12:57 amYeah, the image is there, but really dark, I can play around w/ the Hue & Lum curves to make the image appear, albeit very funky in coloration. I just missing some setting or have something set wrong cuz the image is there, it’s just barely there.
I have an ATI card, the computer is only two months old, so pretty new hardware……
I’m connecting to the HDTV via the mini monitor out connection on the MP and the HDMI in on the back of the tv/monitor.
Second attempt at attaching screen shot…..
Bill Hanson
April 28, 2011 at 2:30 amYeah, the image is there, but really dark, I can play around w/ the Hue & Lum curves to make the image appear, albeit very funky in coloration. I just missing some setting or have something set wrong cuz the image is there, it’s just barely there.
Thomas Anderson
May 3, 2011 at 2:15 amYour Scopes issue is caused from the HDMI connection and Snow Leopard itself. It’s not related to the ATI card or FCPS software. If you use a DVI connection your Scopes Dark Image issue will be solved. I know firsthand as I had the exact same issue using an NVidia video card and OSX 10.6.7
Bill Hanson
May 4, 2011 at 2:55 amHmm, just bought and connected the DVI to HDMI cable, to no avail…..was I suppose to make any other changes in settings for this to take affect??
Thanks for the advice, will keep tweaking until I get it solved.
Thomas Anderson
May 4, 2011 at 3:35 amDVI to DVI will work with no settings adjustments needed if your monitor has a DVI port. HDMI v1.3 cables should work as well. There are so many versions of HDMI v1.4 that you need to physically check which HDMI cable you have. Also you need to reverse connect the HDMI cable as some if not all v1.4 HDMI cables are unidirectional. HDMI is a nightmare because of HDCP, that DVI does not have.
I dont personally know about DVI to HDMI but obviously it does not work either.
Thomas Anderson
May 4, 2011 at 4:45 amDVI to DVI will work with no settings adjustments needed if your monitor has a DVI port. HDMI v1.3 cables should work as well. There are so many versions of HDMI v1.4 that you need to physically check which HDMI cable you have. Also you need to reverse connect the HDMI cable as some if not all v1.4 HDMI cables are unidirectional. HDMI is a nightmare because of HDCP, that DVI does not have.
I don’t personally know about DVI to HDMI but obviously it does not work either.
Also if you are at 1920×1080 resolution you can lower your screen res down one step to avoid HDCP altogether.
