Activity Forums Apple Final Cut Pro Legacy FCP Color and Gamma Handling on 4:4:4 RGB Media
  • FCP Color and Gamma Handling on 4:4:4 RGB Media
    Posted by Tobias Heilmann-schuricht on August 21, 2008 at 7:07 am
    Hi Everybody.
    We shot RAW footage (RED). Converted (First Light CC) to 10 Bit DPX. Converted to AJA 10 Bit 4:4:4 RGB Codec. Went to Color to grade (10 Bit Mode). Exported in the same AJA Codec, imported to FCP (6.0.3), the timeline matches the codec settings. Clips playback fine (look great), the image is identical to that in Color. As soon as I render anything with those clips (crop, filter, size, etc. doesn’t matter what) I see a dramatic shift in what I perceive to be a darker Gamma Level. I see this both in the Viewer, as well as the Kona3 Dual Link Output.
    The render settings of the time line are RGB.
    Can someone explain what might be happening here? How does FCP really handle RGB footage? FCP is YUV native, is that correct?
    I could just readjust the gamma an be (visually) happy. But this defeats the purpose, doesn’t it? Constantly jerking a picture back an forth.
    Any thought on this would be appreciated,
    Tobias
    In Touch Media Entertainment
    Munich, Germany
    Charles Taylor replied 18 years ago 6 Members · 15 Replies
  • 15 Replies
  • Rafael Amador
    August 21, 2008 at 9:18 am
    Hi Tobias,
    Is the setting of your sequence codec Full range?
    [Tobias Heilmann] “FCP is YUV native, is that correct? “
    No really. FC is a Video Editing application and video is YUV.
    But FC works perfect in RGB. In fact until three or four years ago all the FC effects and transitions rendered in RGB.
    When you change from one color system to the other is normal that happens some shifts in colors and gamma,but when you fallow all the process in one or the other this shouldn’t happens.
    rafael
    http://www.nagavideo.com
  • Tobias Heilmann-schuricht
    August 21, 2008 at 9:34 am
    We used the full range, as we wanted to keep the field open until the time we needed to narrow it down.
    Of course I am not sure whether Color exports the exact same way, as I ony choose the codec.
    Does FCP not support this?
    Munich, Germany
  • Rafael Amador
    August 21, 2008 at 11:33 am
    In Color you have no option so I guess is Full range. In FC you can choose, this is why I suggested to check how was set.
    Rafael
  • Gary Adcock
    August 21, 2008 at 12:40 pm
    [Tobias Heilmann] “Any thought on this would be appreciated, “
    Tobias
    the only true way to handle RGB files in FCP is to NOT make them into video, to maintain the data correctly you have to
    make sure that you set FCP to render in RGB, not adjust Gamma correction, and not use filters or transitions that are not 10bit.
    and turn off the RT engine – you will need to work in SAFE RT.
    This is as much a QT issue as it is an FCP issue, QT is Natively 8bit too.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Jeffrey Di lullo
    August 21, 2008 at 2:39 pm
    Tobias,
    I am not a red user, but I did come across these two white papers:
    https://www.coremelt.com/support/workflow/red-camera-10-bit-color-online-workflow-with-fcp-6.0.2.html
    and this one:
    https://www.coremelt.com/support/workflow/codec-and-effects-limitations-for-10-bit-online-workflow-with-final-cut-pro-6.0.2.html
    These papers discuss how FCP handles 10-bit material and may point you in the right direction. The basic gist of the second paper is that very few FCP effects are 10-bit enabled and FCP never tells you when it takes 10-bit material down to 8-bit on effect that are not capable of 10-bit rendering.
    Hope this helps.
    Jeffrey Di Lullo
    bbc&s video communications
    August 21, 2008 at 2:56 pm
    Thank you.
    I have not read those two papers yet… but it goes straight to my question: How do I know what FCP is doing to my footage?
    We even tried just re-exporting the AJA 10 Bit RGB 4:4:4 clip from the timeline without doing anything to it at all. We then compared the exported clip to the clip that Color generated. The FCP clip is darker.
    We compared the two clips by viewing them via AJA TV, our Kona3 via Dual Link Out.
    My head is full question marks…
    Munich, Germany
    August 21, 2008 at 2:57 pm
    Thank you.
    Munich, Germany
    August 21, 2008 at 3:15 pm
    …ok I just read those links. Thank you! Very interesting.
    Can’t say that the question marks have vanished. These papers explain a problem, which is yet of a totally different scope.
    From reading those papers I still can not discover, why FCP would change the look of my footage just by placing it in a timeline (identical to the footage) and then exproting it from there…. Hmmm.
    Munich, Germany
  • Rafael Amador
    August 21, 2008 at 4:13 pm
    Well, is clear. The only thing you can do with 10RGB footagein FC without spoil it, is to cut and export without re-compression.
    In the moment that you render, your 10b RGB become a 8b RGB. So instead of having 1024x1024x1024 colors, you have 254x254x254.
    The only better solution than the one pointed in the articles, is to use Sheer !0b YCbCr 444.
    You would keep the most of the color information from the 10b RGB 444.
    rafael
  • Martin Baker
    August 24, 2008 at 9:45 am
    My understanding is that imported RGB media is affected by the gamma setting in User Preferences > Editing > Imported Still/RGB Video Gamma.
    If you haven’t already, you might want to change it from the default setting of “Source” and run some tests again.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
