Activity › Forums › Apple Final Cut Pro Legacy › FCP- changing from 6.03 to 6.02
Posted by Tyson Hepburn on May 21, 2008 at 4:49 amI need to move a half finished project from fcp 6.03 to fcp 6.02 (just realized I had to do this..) is there any easy way to do this? hopefully without having to upgrade or downgrade either system?
Rafael Amador replied 18 years, 4 months ago 2 Members · 3 Replies -
Rafael Amador
May 21, 2008 at 5:08 amTry exporting an XML.
Mac OX 10.5.2-FC 6.02-QT 7.4.1
G5 2x2Gh 4GbRAM-BlackMagic Extreme
PMBP 17″Core2Duo 4GbRAM-AJA ioHD
JVC DTV-17″
SONY EX-1 . SONY PD170
..and always a big mess on top of the table. -
Tyson Hepburn
May 21, 2008 at 5:42 amare there any risks to moving a project from 6.03 to 6.02: is the transition usually smooth?
Rafael Amador
May 21, 2008 at 8:51 amUsing an XML there is no risk at all. The matter is, if its works or not.
An XML is basically a description of your sequence that can be read by older FC versions or even by other application (like PP).
The complex your project, the difficult to be “rebuild”. If your sequence contains only cuts, easy. Multilayers, transitions, filters complicate things, while some of the properties or parameters can be simply not understood by the”new” appilcation.
Just try. Export an XML of your FC 6.0.3 and import it to 6.0.2. See the results.Mac OX 10.5.2-FC 6.02-QT 7.4.1
JVC DTV-17″
