Activity Forums Apple Final Cut Pro Legacy FCP capture w Canon Vixia HV30
  • FCP capture w Canon Vixia HV30
    Posted by Richard Chenoweth on July 28, 2009 at 5:04 pm
    I see someone else has had a little trouble with Log and Capture also.
    I have FCP 6.0.6 on a MacPro Intel (2008). Camera is a Canon Vixia HV30.
    I plug in to Log and Capture. FCP settings: 1080i60 as the compressor,
    HD 1440×1080/Upper
    Problem: The MacPro recognizes the camera because it appears in System Profiler
    as a Firewire connection. The camera recognizes that it’s plugged in because the connection
    appears on LCD. iMovie launches and automatically prepares to import footage from camera without
    a problem. But when I launch FCP 6.0.6 and go to Log and Capture, FCP does not recognize
    any connection or any device whatsoever. I have tried turning them on in various sequences.
    Is there something I am missing here? It shouldn’t be this difficult. I can always import using iMovie
    and then simply use the footage in FCP.
    Rich
    Richard Chenoweth replied 14 years, 6 months ago 7 Members · 13 Replies
  • 13 Replies
  • Steve Yu
    July 28, 2009 at 5:58 pm
    Is iMovie launching automatically when the HV30 is plugged in? If so maybe you need to disable this option so that iMovie isn’t reserving the firewire input.
    If this isn’t the case, you might try the following:
    1) Connect the HV30 to your Mac Pro
    2) Press play on the camera (with a tape with timecode) to ensure the playback mode is HD, then stop the tape
    3) Go to Easy Setup and select your input device settings — I would choose HDV.
    4) Press Command 8 (or choose Log and Capture).
    It should work, so I’m not sure why it isn’t showing up for you… (I have 4 HV20s and have used them as decks on two different Mac Pros.
    Good luck!
  • Richard Chenoweth
    July 28, 2009 at 7:17 pm
    Hmmmm…. thanks Steve!
    When at the beginning of the tape it displays that it’s plugged in and
    indicates HDV/DV.
    When I playback for a few seconds, it indicates DV-OUT instead.
    I recorded this tape in HDV but at the very end I used it to dub from a VHS player
    which kicked it into DV mode…
    Did I mess up tape? Can’t figure out how to get it to HDV-OUT instead…
    Thx!
  • Richard Chenoweth
    July 28, 2009 at 7:31 pm
    Hi Steve,
    Thanks, it works now!! It had been set on DV-OUT. I realized I could not change it back without
    first unplugging the HDV/DV-OUT cord. Switched it to HDV-OUT and now L&C grabs it…
    Thx again,
    Rich
  • Steve Yu
    July 31, 2009 at 3:06 am
    I’m not sure my input helped, but I’m glad you got it working!
    FCP is a bit picky with the HV20/HV30 – the camera may think it’s in DV playback mode if you’ve played some DV footage in it the last time you powered on, so Log and Capture won’t like it if it’s expecting HDV, and vice versa.
    After a while you’ll get a hang of the quirks!
    I’ve had a bunch of similar issues with the Voice Over tool and my INSPIRE pre-amp. I’ve found that if I switch the payback frequency between 44khz and 48khz the mic sometimes comes on magically. (just a random note)
    Have fun!
  • David Naugle
    May 6, 2010 at 4:31 pm
    Damn. Unplugging is definitely the key.
  • Kyrl Henderson
    March 14, 2011 at 1:05 am
    Thanks for the method on getting my HV20 recognized. It works!
    I am currently having problems with my HV20 playing back clips which are :02 and less long. Every time i put in a tape it will no longer capture longer segments. Any ideas?
    thanks
  • Liane Hunter
    July 27, 2011 at 5:58 pm
    I have a Canon Vixia HV30 and I am trying to connect it to FCP 7 using a Firewire 400 cable. Neither FCP or iMovie will recognize the camera. I set the FCP settings to:
    Sequence Preset: HDV – 1080i60
    Capture Preset: HDV
    Device Control Preset: HDV Firewire
    Video Playback: None
    Audio Playback: Default
    When I plug my camera into the computer, nothing happens on the camera screen. Is the camera supposed to acknowledge that it is plugged into a computer? Are there camera settings I need to change in order to connect?
    Any help would be greatly appreciated.
  • Richard Chenoweth
    July 27, 2011 at 7:15 pm
    Make sure the camera is set for playback in “HDV” (not DV). Also, make sure camera is on. It sounds like your Easy Settings in FCP are correct, although I only have FCP6.
    I’ve had issues in FCP (something I’ve overlooked) but iMovie ususally recognizes the camera immediately
    with no problems.
    Richard
  • Marianne Souliez
    October 16, 2011 at 7:13 pm
    Hi Richard,
    I have the same settings as the person who asked that question, and I have put HDV in the playback but FCP still does not recognize the camera.
    Thank you for your help, if you have any idea!
    Marianne
  • Richard Chenoweth
    October 16, 2011 at 8:09 pm
    Hi Marianne,
    When you are in FCP6 (6 is what I have) make sure the Audio/Video Settings are: HDV-1080i60/HDV/HDV Firewire Basic for the first three settings.
    Disconnect Canon Camera from computer and make sure it’s “output” says HDV (not DV).
    Then plug back in and turn it on.
    Check System Monitor to make sure your computer shows that a Canon Camera is connected through Firewire.
    Go back into FCP and “Command-8” to launch the Log & Capture. It should see it… it got frustrating for me, too, but it’ll work…
    Rich
