Activity Forums Apple Final Cut Pro Legacy FCP Capture from HDV 480i/30p?
  • FCP Capture from HDV 480i/30p?
    Posted by James Holdridge on June 9, 2010 at 7:23 pm
    I am trying to properly capture from 3 HDV tapes of the same event. I am using a Sony GV-HD700 deck.
    All 3 tapes were shot on Panasonics.
    DVX100
    DVX100A
    HDX200
    The DP said they were all set to 480i/30p.
    When I easy setup and capture, the image seems to be significantly stretched and cut off at the sides. And when I try to specify various HDV settings I get a pop-up that claims my settings are incorrect for my deck. There are no settings that specify 480i.
    What specific capture settings should I be using in FCP?
    I’ve never captured from HDV.
    -j
    Michael Sacci replied 16 years, 3 months ago 2 Members · 1 Reply
  • Michael Sacci
    June 9, 2010 at 8:25 pm
    You do not have HDV tapes, you have DV tapes. Use DV presets. for the 30p you change the field dominance to none.
