Activity Forums Apple Final Cut Pro Legacy FCP can’t LogAndTransfer my Red-Epic footage
  • FCP can’t LogAndTransfer my Red-Epic footage
    Posted by Kazumi Hatori on November 6, 2011 at 10:20 am
    I’m using FCP7, installing latest Red software/fcs3 plugin,
    shot footage by Red Epic with 4K and 2K.
    I worked with Red-one MX with FCP before, it was fine.
    Now I’m trying to transcode the footage to prores, but fcp cannot recognize my epic footage,
    what happened? what can i do?
    I can use Redcine-X to do that, though, it takes forever.
    Please help!!!!!!thanks!
    Kazumi Hatori replied 14 years, 6 months ago 2 Members · 2 Replies
  • Neil Patience
    November 6, 2011 at 8:33 pm
    Hi
    I am pretty sure that the Epic is not compatible with the Log and Transfer tool.
    I believe that it does not create proxy files like a Red One and that Redcine X is the only answer at the moment.
    You can accelerate process that with a Red Rocket card but sadly they dont come cheap.
    I think you can make proxies in Redcine but have not tried that so cant advise if that would be quicker than just using Redcine alone.
    best wishes
    Neil
    http://www.patience.tv
  • Kazumi Hatori
    November 13, 2011 at 2:26 am
    Just replying that I’ve found simply solution.
    *used Adobe media encoder to transcode all R3D to 640×360 prores proxy, edit with Premiere, and link to R3D files when finish.
    And I’ll then import to Aftereffect to apply effects/color correction.
    That’s works for me~
