Activity Forums Apple Final Cut Pro Legacy FCP – can’t hear tapes playing back from deck
  • FCP – can’t hear tapes playing back from deck
    Posted by Nicole Cattell on August 11, 2008 at 1:53 pm
    I’m trying to play back a DV tape from my deck on FCP to view it. BUT I can’t hear it coming via firewire from the deck. I can see that there is audio there and if I digitize it and play it back from FCP, I hear it. But i don’t hear it coming from the deck into FCP. Is there some configuration or setting I need to change? TIA!
    Nikagain
    Nicole Cattell replied 18 years, 1 month ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    August 11, 2008 at 2:15 pm
    Listen from the deck.
    The audio is, by default, intentionally MUTED to the Mac’s speaker output during Log and Capture.
    So you should normally monitor the audio directly from the camcorder or deck you are using to capture. (It is the preferred method.)
    CAUTION:
    Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”
    However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
    In FCP4x and earlier:
    Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
    “Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
    Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
    The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
    In FCP5x and later:
    In the Record Tool:
    Clip Settings, near audio buttons, choose: Preview: “ON”
  • Nicole Cattell
    August 11, 2008 at 2:56 pm
    THANK YOU!!! That worked. I have one follow up question that is sort of related only in that I discovered the capture presets thanks to your reply- what should my capture presets be if I am shooting on Panasonic’s DVX 100A in the 24PA mode??? THank you again!
    Nikagain
