Activity Forums Apple Final Cut Pro Legacy FCP Canon 7D H.264 workflow
  • FCP Canon 7D H.264 workflow
    Posted by Kit Carruthers on November 4, 2009 at 6:28 pm
    Hello,
    I’m testing workflow for a Canon 7D through FCP.
    I recently imported the H.264 clips directly into FCP, and edited a test sequence from that. I then exported a quicktime to send to the lab to be transferred to HDCam SR for a projection test.
    When I exported this quicktime (current settings, trying to keep it all native) I noticed it was only about 500MB for a 12 minute sequence. However, if you look at the individual clips, a 60 second clip is about 400-450MB. Why is the exported Quicktime so small? I was expecting it to be at least 6 or 7 GB based on the size of the files created by the camera. Is this an H.264 thing? Where is the extra data going?
    In the future we will be converting to pro-res for the edit, but I wanted to try and keep everything native for the test in case converting to pro-res adds any kind of additional compression to the footage. (does it?)
    Thanks for any insight you might have!
    -K.
    Jeff Handy replied 16 years, 10 months ago 3 Members · 2 Replies
  • Zane Barker
    November 4, 2009 at 6:44 pm
    [Kit Carruthers] “I recently imported the H.264 clips directly into FCP”
    H.264 is a delivery codec NOT a editing codec.
    [Kit Carruthers] “In the future we will be converting to pro-res for the edit”
    Good thats exactly what you should do. Editing will be so much easier.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Jeff Handy
    November 4, 2009 at 6:54 pm
    I see in the new ProRes line, there is an option to use 10-bit color sampling. Anyone know if the 7D is acquiring 10-bit to make that worth while?
    HandyGeek
