  • Posted by Aggie_man on June 29, 2006 at 11:09 pm
    Is there an issue with type & feild dominance in FCP 5 ?
    After our Agency upgraded from 4.5 to 5, we are experiencing an awful problem.
    In a nut shell: Sequence setting” Field dominance set to lower (as should be) video looks great. But ANY type generated in fcp or imported from PhotoShop (as tiff or layered) looks chunky, broken-up and ghostly.
    If I switch the Field dominance to “NONE” the type looks great. Sharp and fine. BUT the video then starts to break-up and ghost.
    Didn’t have this problem in 4.5
    Looking at a final product. NTSC Monitor, Burned to DVD, etc.
    Trashed prefs didn’t work
    It is “bitmapping anything that is “still” Type, images etc.
    I always look at my 20″ NTSC monitor
    If I hook up a TV direct (via the dsr-45) bypassing the NTSC, burn a DVD or create a QT file to view on the computer monitor, with the field Dom set to lower as should be, Type (generated from ANY source) and any still images, look very bad. (exporting dv ntsc 48khz)
    Ghosting, chunky, pickleated.
    Again if the Field Dom is set at none type and graphics look as good as anything I
    Aggie_man replied 19 years, 10 months ago 2 Members · 2 Replies
  • Nick Toth
    June 30, 2006 at 12:41 am
    Have you updated to 5.0.4? The problem you describe was in 5.0
  • Aggie_man
    June 30, 2006 at 4:32 pm
    Yes I have and the problem is still there.
    5.1.1???
    Aggie
    vitrorobertson.com
    san diego
