Activity Forums Apple Final Cut Pro Legacy FCP black screen
  • FCP black screen
    Posted by Marjo Parascandalo on June 29, 2011 at 12:36 pm
    HI, I have just bought a new iMac (2.5GHz Intel Core i5 with 8GB 1333 MHz DDR3 ram) and installed Final Cut studio 2 on it. Everything works good except for Final Cut. When I launch it the whole monitor goes black. If I press the command key + Q, I will have the desktop again. Can this problem be fixed?
    Marjo
    Marjo Parascandalo replied 15 years, 2 months ago 2 Members · 2 Replies
  • Everest Mokaeff
    June 29, 2011 at 1:55 pm
    Try to install all available system and pro application updates from apple to see how it’ll play out.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Marjo Parascandalo
    June 30, 2011 at 5:42 am
    Thanks for your response. I tried all that but still did not work. However it turned out to be that FCP was in full screen mode and since I did not have anything in it I was seeing all black. The escape button solved the problem. Thanks again.
    Marjo
