Activity Forums Apple Final Cut Pro Legacy FCP audio output – Is there any way to do this?
  • FCP audio output – Is there any way to do this?
    Posted by Herb Sevush on October 10, 2008 at 8:06 pm
    I’m trying to layback to tape and I’m having trouble doing what I want from within Final Cut.
    I’m working with DVCPRO HD 720P30.
    I have a timeline with a 2 track stereo mix.
    I want to layback to tape via firewire with a stereo mix going to ch.1 and ch.2, and a mono mix of both tracks going to ch.3 and ch.4.
    Is there any way to do this from within Final Cut without first building a mono down mix with an external application.
    Herb Sevush
    Zebra Productions
    Herb Sevush replied 17 years, 11 months ago 3 Members · 3 Replies
  • Shane Ross
    October 10, 2008 at 8:44 pm
    Not that I know of. You cannot patch the audio from the timeline tracks to two separate output tracks. When I do this I have a mixdown…stereo on 1 and 2, and then the mono mix on 3 and 4.
    Shane
  • Jamie Pickell
    October 10, 2008 at 8:57 pm
    Herb,
    I think you want to open your Sequence settings and under the Audio tab, set the audio outs to 4, then set your first two outs to be stereo, and the second to be mono. At least that’s how I would do it if I were laying back via a Kona card.
    Jamie Pickell
  • Herb Sevush
    October 10, 2008 at 9:46 pm
    Jamie –
    I have the audio outputs set to 4 channels:
    Stereo pair on ch.1 & ch.2, dual mono on ch.3 and ch.4.
    However in the timeline you have to set where each audio track is output to , you can choose either 1&2,3 or 4. so I can set tracks 1 & 2 to output to stereo pair 1&2, but I can’t figure out anyway to route those tracks to the mono mix outputs. If i simply copied the pair to tracks 3 & 4, then I would get each track alone as a mono track on 3 & 4 but that’s not a mono mix.
    It seems like the only way to do this is export an audio file, convert it to a mono mix, then lay that track down on 3 and 4. I was hoping there was some way to internally do the mono mixdown in final cut.
    Herb Sevush
    Zebra Productions
