Activity › Forums › Apple Final Cut Pro Legacy › FCP Audio Mixer
  • FCP Audio Mixer
    Posted by Chuck Purnell on April 30, 2011 at 11:53 pm
    Can someone explain the audio mixer thats included in FCP? I just shot a concert last night and I have the audio feed I was getting from the board on Channel 1 & 2. Channel 3 & 4 has shot gun microphone. I was shooting with the Panasonic HVX200 and I was surprised to see that it recorded 4 channels of audio I had it set up to just take a LINE IN feed from the board on 1 & 2. At any rate I need to pot down Ch. 3 & 4 so I can just hear the good audio and they keep slowly creeping back up on their own! Is there anything I can do to stop Ch 3 & 4 from doing that? I DO need the audio for room noise and crowd applause and that sort of thing. It almost feels like the mixer is in automatic mode and not manual mode. If I lower Ch1 & 2 they stay low till I make another adjustment but the other 2 channels do what they want.
    Your thoughts…
    Cre8tive Minds Entertainment, LLC
    Chris Tompkins replied 15 years, 5 months ago 3 Members · 2 Replies
  • Cody Walters
    May 1, 2011 at 1:46 am
    Sounds like you might have keyframe audio enabled. Try disabling that. It’s in the top right corner of the mixer. Then you should be able to make a full level adjustment. You can also go to modify, levels, and make an absolute change of you audio levels.
    Mac Pro 2.26GHz 8 Core
    16 GB 1066 MHz DDR3
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
    http://www.codywaltersvideo.com
  • Chris Tompkins
    May 1, 2011 at 1:50 pm
    delete your tracks 3&4
    Chris Tompkins
    Video Atlanta LLC
