Activity › Forums › Apple Final Cut Pro Legacy › FCP and panasonic SDX 900 16X9 footage
Posted by Jamie Nabers on June 15, 2006 at 2:21 pmhey guys,
im experimenting with our SDX 900 camera and shooting in 16X9 mode. I want to know to the steps to edit and output the footage.
i have set the following settings….
1. capture settings… 10bit uncompressed… with anamorphic checkbox turned on.
2. sequence settings… 10 bit uncompressed… with anamorphic checkbox turned on.
those match up… but during output to a beta deck… it still looks squeezed and not letterboxed like it should. when i put the anamorphic footage in a 4 X 3 sequence, the footage is letterboxed but needs to be rendered. any thoughts on things i might be doing wrong?
thanks,
j
Jeff Carpenter replied 20 years, 3 months ago 3 Members · 9 Replies -
Jan Crittenden livingston
June 15, 2006 at 2:27 pmYou are not doing anything wrong. Your monitor will need to be switched to a 16:9 mode.
Best,
Jan
Jamie Nabers
June 15, 2006 at 2:47 pmJan,
I have set my monitor to the 16X9 setting. My viewing is not my problem. When i output it to tape, the images are not letterboxed, they are squeezed. How do i get the images going to tape to be letterboxed?
thanks,
j
Jamie Nabers
thanks,
j
June 15, 2006 at 2:51 pmYou will have to import and set it into a 4:3 window and render it that way. The deck is not caring about how long the line is and so if you are working in an anamorphic signal, then that is what is will record. If you really want it to record a 4:3 with a letterbox, that is what you will have to feed it.
Does that make sense?
Jan
Jeff Carpenter
June 15, 2006 at 2:55 pmHow do i get the images going to tape to be letterboxed?
==========You said it in your first post. Put it in a 4×3 timeline and render it. That’s what you have to do to get a letterboxed master.
If you want a letterboxed master, that’s what you should do, but I suggest ALSO making another master where everything’s squeezed. That will be your anamorphic master and it will retain full quality. The letterboxed version will look fine on 4×3 TVs, but if you ever want to copy the master to some other widescreen format or play it on a widescreen TV in the future, you’ll want to use the anamorphic master for that, not the letterboxed one.
So I suggest you make 2 masters, one letterboxed and one anamorphic.
Jamie Nabers
June 15, 2006 at 2:56 pmyes, thank you.
so FCP wont output letterboxed? only an anamorphic signal to tape? I will have to render the footage in a different sequence with anamporphic turned off, to get it to be letterboxed on output?
Jamie Nabers
June 15, 2006 at 2:58 pmThank you guys ! thats what i needed to know.
seems like FCP should support something like that though. where all image quality is retained, just unsqueezed during output.
thanks again,
j
Jeff Carpenter
June 15, 2006 at 3:05 pmseems like FCP should support something like that though. where all image quality is retained, just unsqueezed during output
======It’s a matter of computer hardware power. You’re asking it to re-arange every single pixel of every single frame of your entire video. Most modern Macs can do a pretty good job of this live, which is pretty amazing if you think about it, but they can’t promise that it will be 100% correct and free of errors or full-quality all the way through. So you have to render it.
Jeff Carpenter
June 15, 2006 at 3:09 pmI’ve noticed something in your terminology that might explain your initial confusion.
Here’s what’s really going on:
1) Image that’s full-frame with skinny people = Un-Squeezed, Original footage
2) Letterboxed footage = Squeezed down videoYou’re calling #1 squeezed when in fact it’s not. That’s what the camera shot and recorded. #2 is the squeezed video.
It’s a small point, but it helps explain why you didn’t originally understand why Final Cut had to render the letterboxed version.
