Activity › Forums › Apple Final Cut Pro Legacy › FCP and HDV????
FCP and HDV????
Posted by Micah Ginn on October 19, 2006 at 3:30 pmDoes anyone know if there are HD formats unsupported by FCP?
For instance, I have shot in 24p HD, 30p HD, and HDV-SD60p, but only the 30p will import and play properly in FCP.
Is it how I’m capturing it, my sequence settings, or other? I have tried all number of combinations cannot get the 60p to work.
Any ideas?
Ozzieforbes replied 19 years, 9 months ago 5 Members · 8 Replies -
Jerry Hofmann
October 19, 2006 at 4:16 pmWhat is HDV-SD60p???? is this the conversion done in camera from HD to DV?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Chris Borjis
October 19, 2006 at 4:22 pm[Jerry Hofmann] “What is HDV-SD60p?”
It’s a format that the JVC HD100U supports.
I don’t think that will work with regular workflow.
You have to capture it with dvhscap and convert/conform
it with mpeg stream clip.thats the no-cost way.
you need fcp 5.1.2 to do the 24p editing.
30P should work just fine.
Micah Ginn
October 19, 2006 at 4:23 pmman, I wish I knew that.
the camera has several HD settings…on of which is HD-SD60p…and when I shot in that, the footage will not move into FCP’s timeline.
what’s odd is that the footage will capture, and it will play in the viewer, but when moved to the timeline (sequence) it will not play, even after rendering. It just becomes a big, green block of non-video.
Jerry Hofmann
October 19, 2006 at 4:57 pmOh brother… ANOTHER freaking format. Just what we need! It’s getting stupid.
Jerry
Arnie Schlissel
October 19, 2006 at 9:03 pm[micah ginn] “Does anyone know if there are HD formats unsupported by FCP? “
Short answer: FCP has supported HD via 3rd party capture cards since at least version 3.x, & had been supporting DVCPro HD & some forms of HDV since version 4.5.
Longer answer: JVC & Cannon don’t play by the same rules as the rest of the industry. If you’re using JVC or Cannon gear, you may be out in the wilderness. Get details from them.
Arnie
On location in Moscow for Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Ozzieforbes
December 19, 2006 at 2:17 amI shot a comercial with my jvc pro hd in hdv-sd 60p and I didn’t find a way to capture in fcp 5.1.2
Did you solved this problem?oz
