Activity › Forums › Apple Final Cut Pro Legacy › FCP and HD capture from Panasonic frame rate converter
  • FCP and HD capture from Panasonic frame rate converter
    Posted by Neil Harris on August 16, 2005 at 10:46 am
    hi there
    i’m trying to capture in some HD footage from a panasonic varican through a Panasonic frame rate converter – AJ-FRC27e
    i’ve managed to log a clip but so far my machine crashes when i try to batch capture – does anyone have experience of this and know the correct video settings for using this bit of kit??
    thanks if you can help…
    Neil
    Mathias replied 21 years, 1 month ago 3 Members · 2 Replies
  • Gary Adcock
    August 16, 2005 at 1:42 pm
    [Neil Harris] “i’ve managed to log a clip but so far my machine crashes when i try to batch capture – does anyone have experience of this and know the correct video settings for using this bit of kit??”
    the FRC was not built for this and I have never successfully captured from one it cannot access the info on the HD the same way that it needs to from tape– the crash is due to no pre / post roll available.
    try a crash capture first but since you must have the ability to capture HDSDI use your capture card direct from the camera or deck and convert it to DVCPROHD and use the software FRC to convert your footage.
    gary adcock
    Studio37
    HD and Film Consultation
  • Mathias
    August 24, 2005 at 12:26 pm
    I tried to reply to this post earlier but something went wrong w my cow user account. Anyway:
    I
