FCP and Flame versions of same material don’t match
I encountered a peplexing situation today. Our editor exported some material from FCP 4.5 as a TGA sequence for use in Flame. The original capture was via a Kona using Uncompressed 422 8-bit from SDI in. To my surprise, the look of the FCP frames did not match the same material recorded into Flame via it’s SDI input. The whites seemed fine but gamma seemed wrong. The difference was more complicated than could be replicated by re-mapping 16 to 0 and 235 to 255 which is often the culprit in this kind of situation. Fearing that FCP could not be trusted to work transparently, I did a test of the complete video loop by capturing from and then editing out to Digital Betacam and, what do you know? It is transparent. So what’s up with the export? Any pearls of wisdom on this would be much appreciated.
