Activity › Forums › AJA Video Systems › FCP – AJ IO HD – AJ-HD1400p – Tri-Level Sync Generator
  • FCP – AJ IO HD – AJ-HD1400p – Tri-Level Sync Generator
    Posted by Eric Beaudry on May 20, 2010 at 6:05 pm
    Trying to figure out the proper workflow to edit to tape from FCP using an AJA IO HD and an AJ-HD1400p deck.
    Format is 720p 59.94
    Need a simple answer. Is a tri-level sync generator (like a Gen-10) needed? Yes or no.
    If not, what is the proper workflow (deck settings, connections, etc.)
    Thanks.
    Bonus Question:
    Would something like a gen-10 possibly help with tape trouble issues during capture?
    Go slow to hurry up.
    Jeremy Garchow replied 16 years, 4 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    May 20, 2010 at 8:46 pm
    You can use regular bi level sync for 720p60 (as it’s 60hz).
    For capture, the AJA products reference incoming video so the sync gen is not needed.
