Activity Forums Apple Final Cut Pro Legacy FCP Adjusting volume on both audio tracks at once
  • FCP Adjusting volume on both audio tracks at once
    Posted by Philippe Gosselin on March 8, 2011 at 1:07 am
    Hello!
    I’m trying to adjust the volume on certain clips in my sequence. Normally when I adjust the volume (using the level indicators on the timeline), the change is reflected on both audio tracks at the same time. But for some reason in this sequence I have to adjust each audio track individually for every clip. I have linking turned on, so I don’t know what I could be missing. Is there another setting for this?
    Thanks for your help!
    –Philippe
    Philippe Gosselin replied 15 years, 5 months ago 4 Members · 4 Replies
  • Chris Borjis
    March 8, 2011 at 1:12 am
    they are mono audio tracks.
    I don’t know how to change it other then exporting the audio as stereo then importing it back in.
  • Matt Killmon
    March 8, 2011 at 1:29 am
    If they are actually stereo audio that somehow got ingested as monaural stems, you could mark them as a Stereo Pair (Opt+L, different than linking). That should accomplish what you want.
  • Michael Gissing
    March 8, 2011 at 1:45 am
    Select clips. Opt+Apple+L brings up a dialog box to enter relative gain increase or decrease for all selected clips. Easier than loading into the viewer and adjusting with a mouse
  • Philippe Gosselin
    March 22, 2011 at 4:34 am
    This does indeed work, thanks for the tips!
