Activity Forums Adobe Premiere Pro FCP 7 XML to PPro Crashing
  • Tim Richardson
    September 20, 2011 at 10:05 pm
    [Todd Kopriva] “Sorry, but can you confirm that you’re running Premiere Pro CS5.5 (5.5.1). “
    confirmed. i downloaded it from Adobe.com and installed. when i open Premiere Pro it says “version 5.5.1”
    i even exported a fresh XML from FCP 7 to test it and the sequence crashed in Premiere Pro on playback.
    thanks for checking on this, Todd. i was hoping the 5.5.1 update would solve my problem.
    in other news – apparently FCP X just updated to support XML.
    tim richardson, senior editor
    encyclomedia
  • Todd Kopriva
    September 21, 2011 at 4:10 am
    Drat. Please submit a detailed bug report:
    https://www.adobe.com/go/wish
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Jon Hiseman
    September 21, 2011 at 6:53 pm
    5.5.1 has fixed my problem
    Original files from Sony EX3 – XDCAMEx 1080p25
    Convert to Prores Proxy
    9 screen multiclip edit in FCP 7.0.3
    Collapse multiclip
    Reconnect to original XDCAM EX 1080p25
    Media Manage in FCP to Prores 422 (HQ) (not for better file quality but intend a lot of plug and color processing
    Export a XML
    Import into PPro 5.5 – crash as thumbnails are drawn
    Update to 5.5.1 – The XML import works perfectly
    Test: same procedure as above but export a XML at the Prores Proxy stage
    Works perfectly in 5.5.1
    Good Job.
    I used to be Jon Hiseman but I’m feeling better now.
  • Matt Doe
    September 29, 2011 at 6:33 pm
    Still have the same issue with 5.5.1
    ProRes crashes when I try to playback after XML import. I did notice that Premiere is changing the edit mode of my sequence from ProRes to XDCAM.
    Meaning, I import a ProRes XML, look at the sequence settings of the imported sequence in premiere, the editing mode now says XDCAM.
    If I take one of the imported prores clips and do a “create sequence from clip” it creates an AJA HD sequence.
    WTF
Page 2 of 2
