Activity › Forums › Adobe Premiere Pro › FCP 7 to PR via XML
  • FCP 7 to PR via XML
    Posted by Divonna Ratliff on February 3, 2020 at 10:04 pm
    Hello, I m importing an xml file into Premiere Pro from a project edited in FCP7. For the most part, everything has transferred successfully, except all of the attributes associated with any text in the project did not transfer. It’s still there, but all centered in the frame, with the font & size changed to a default.
    Is there any way to process the xml file to keep the attributes in Premiere Pro?
    Thank you!
    –Divonna
    seedeerun
    Divonna Ratliff replied 6 years, 7 months ago 2 Members · 2 Replies
  • Shane Ross
    February 4, 2020 at 1:37 am
    NOPE…because the text tools in FCP and Premiere pro are different. YOu’ll have to redo them. Sorry!
    Shane
    Little Frog Post
  • Divonna Ratliff
    February 4, 2020 at 5:05 pm
    Well at least now I know. I suppose that is also the case with the “drift” that happens in the V.O. part of the sound track. Weird that it only happens with the narration & not the music–is it the format? The narration is in wav.
    Thank you!
    seedeerun
