Activity Forums Apple Final Cut Pro Legacy FCP 7 Slip angle in multicam – it is not in sync
  • FCP 7 Slip angle in multicam – it is not in sync
    Posted by Tina Hedegaard on November 20, 2012 at 12:08 pm
    Hi
    I just experienced something annoying. I am editing a comedy show with 6 angles, now after I have done the rough cut I see that one angle is a few frames out of sync – It is the supertotal, so I can hardly see any mouth movement.
    Is there any way to slip just this angle a few frames or is it from the beginning, do the multiclip correctly, and then recreate the rough cut?
    Thanks in advance
    Cheers
    Tina Hedegaard
    Editor | Assisting Editor
    Final Cut Pro 7 | Media Composer 5.5.3/6.0.1.1
    Mac OS 10.6.8| Mac OS 10.7.4
    Phillip Van west replied 13 years, 10 months ago 2 Members · 1 Reply
  • Phillip Van west
    November 21, 2012 at 4:39 am
    You CAN adjust each angle individually. You hold down CNTL-SHIFT and then drag your mouse (horizontally) across the clip (in the multi-viewer) you want to resync. It should display the new relative time offset. It’s in the manual. Hope that helps.
    pvw
    Phil Van West
    Terra Nova Productions
    Denver, CO
    Video Production/Post-Production
    Mac Pro 8-core 2.66GHz / 16GB RAM / OS 10.6.7 / FCP 7.0.2 / QT 7.6
