Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 send to color – not working
Posted by Anna Thora steinthorsdottir on November 7, 2012 at 11:50 amHello friends!
I´m having problems with “send to color” from FCP 7. I have a HDVi50 sequence, removed all attributes and put everything on one videotrack. When I click send to color, the color dialogue box offers me only to open a new project in Color. Not to save or open the sequence I´m sending. Hence my media will not transfer to Color. Anyone with a solution to this?Anna Thora Steinthorsdottir
Producer / Editor
Klipp inc.
ReykjavikRafael Amador replied 13 years, 10 months ago 2 Members · 6 Replies -
Rafael Amador
November 7, 2012 at 12:38 pmYou should get a window offering you to open a new project with the name of the sequence you are sending.
Clicking OK, color should open with the FC sequence on his time-line.
if do not happens like that, try trashing FC’s preferences or Color preferences.
The work around is to export an XML from FC and open it on Color. Then: Send to FC.
rafael -
November 7, 2012 at 12:42 pmThank you for your reply. I already tried to go via XML but it too will not open in Color.
I will try to trash the prefs. It has worked before for various problems.
Thanks again.Anna Thora Steinthorsdottir
Producer / Editor
Klipp inc.
Reykjavik -
November 7, 2012 at 2:13 pmHere is a problem; I really can´t find the preference files on my HD!
I go in the library folder > preferences > but there is no “com.apple.FinalCutPro.plst” nor is there a “Final Cut Pro User data” folder that normally store the prefs and cache files…
How can this be? I have also tried various methods of searching these on my HD, without result and my problem with color is still unsolved. Both apps seem to run ok apart.
Thanks if you have any answers.Anna Thora Steinthorsdottir
Producer / Editor
Klipp inc.
Reykjavik -
Rafael Amador
November 7, 2012 at 3:47 pmYou must look in the User (user name)/Library preferences, not in the HD (HD name)/library/Preferences.
rafael -
November 7, 2012 at 3:53 pmAfter googling a bit i found out about the MacOs Lion´s hidden library folder. Then I found the preference files, trashed them and after also trashing Color preferences and restarting my system, the sending to Color finally works 🙂
Did everyone know about the hidden folder? Well now I know…
You have been most helpful so thanks again Rafael.
All the best,
AnnaAnna Thora Steinthorsdottir
Producer / Editor
Klipp inc.
Reykjavik -
Rafael Amador
November 7, 2012 at 3:58 pm[Anna Thora Steinthorsdottir] “Did everyone know about the hidden folder? Well now I know…”
Well, I heard about 🙂
I’m still on Snow Leopard.
I don’t know why Apple should hide that stuff. They may think we are idiot and should mess with that.
Great that worked.
rafael
