Activity Forums Apple Final Cut Pro Legacy FCP 7 quits at launch?
  • FCP 7 quits at launch?
    Posted by David Block on September 24, 2012 at 2:04 pm
    Hi. I’m David.
    Recently reinstalled FCP7 on my MAC running 10.6.8 Snow Leopard. When I try to launch the software it quits at the point that it is loading an audio plug in, PredatorFX. I’ve searched hi and low for a thread about this with no luck. So decided to post. Here is what I thought was the relevant portion of the log. If something is left out to solve I’ll provide. Has anyone experience this before? Any ideas?
    Process: Final Cut Pro [471]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 5.1.4 (5.1.4)
    Build Info: FCPApp-702211411~2
    Code Type: X86 (Native)
    Parent Process: launchd [212]
    PlugIn Path: /Library/Audio/Plug-Ins/Components/PredatorFX.component/Contents/MacOS/PredatorFX
    PlugIn Identifier: com.RPCX.PredatorFX.component
    PlugIn Version: 1.1.0 (1.1.0)
    Date/Time: 2012-09-24 05:41:02.885 -0700
    OS Version: Mac OS X 10.6.8 (10K549)
    Report Version: 6
    Interval Since Last Report: 205990 sec
    Crashes Since Last Report: 3
    Per-App Interval Since Last Report: 237 sec
    Per-App Crashes Since Last Report: 1
    Anonymous UUID: EEA07443-5213-4FC2-8FCD-02E503D3995D
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000010074
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    David Block replied 14 years ago 2 Members · 2 Replies
  • Steve Eisen
    September 24, 2012 at 5:18 pm
    You will need to find the plug in and remove it.
    Your crash report tells us you are still using v5.1.4
    FCP 7 recommends not having any other version of FCP on your system hard drive.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • David Block
    September 24, 2012 at 5:30 pm
    Thanks very much. I realized after posting that I hadn’t loaded FCP7. I had gone back to FCP 5 to try to resolve the issue. I did find the culprit files that you’re pointing out with the path. I removed and FCP 5 loaded right up. I’m now upgrading to FCP 7 and hope is works. Thank you for your post.
    I’ll update after FCP 7 is done updating.
    David
    David Block
