Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Quicktime Exporting Wrong Size
Posted by Jason Tessmer on September 15, 2009 at 6:07 pmI’m working in FCP 7 and exporting a SD sequence to quicktime. My sequence is set at 720×486 at 29.97 10bit Uncompressed. When I export it out as a quicktime, it makes it 655×480. WHAT? Even when I change the “Current Settings” in the export options to Uncompressed 10bit NTSC, it make the QT 655×480. Why is it doing this and how can I fix it?
Tom Wolsky replied 16 years, 12 months ago 8 Members · 15 Replies -
Brad Elliott
September 15, 2009 at 6:16 pmYou can change the size in the QT options.
Export with Quicktime Coversion/options/size
You will have the option of 720×486 4×3 or
720×486 16×9 in the pulldown. You can also do a custom size.Brad
Tom Wolsky
September 15, 2009 at 6:21 pmAre you using QuickTime Movie or QT Conversion?
“When I export it out as a quicktime, it makes it 655×480”
How do you know that? Where are you getting this information?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
John Pale
September 15, 2009 at 6:31 pmDrag the converted file into the FCP Browser and examine its dimensions.
The dimensions reported by Quicktime Player can be odd, as its converting an SD non-square pixel size to square for display on a computer screen.
Jason Tessmer
September 15, 2009 at 6:35 pmI’m just using Export > Quicktime Movie. I’m NOT using QT Conversion. I try using conversion also but still get the 655 size. I know that this is the size of the movie and not just some display error cause when dropping the movie into a AE comp it’s 655. I never had this issue on FCP 6.
Tom Wolsky
September 15, 2009 at 7:00 pmHow do you know it’s 655? Where exactly are you seeing that>? Have you brought the file back into FCP and check it’s item properties there?
This upgrade of the application has been out a while, and this is the first instance of this issue I’ve seen.
All the best,
Tom
Jason Tessmer
September 15, 2009 at 7:26 pmOpening the QT in the QTplayer and opening info tells me the size. Also when importing the QT into After Effects, it also gives me a size of 655. Now, when dropping the QT back into FCP, it reads as 720×486. This is just strange.
Specs for the system (just in case)
MacPro 2x3Ghz Quad Core
8GB Ram
Nvidia 7300GT
Kona 3 I/O card (6.5 driver)
OS 10.5.8
Xsan 2
Final Cut Studio 3 -
Tom Wolsky
September 15, 2009 at 7:34 pmWhich QT player are you using BTW?
All the best,
Tom
Morten
September 15, 2009 at 8:38 pmBeware Quicktime export wants to export at the size your canvas is set to, unless you specify other…
– No Parking Production –
Finalcut Studio2, Dual G5, Kona 2, ioHD, X-Raid
Tom Wolsky
September 15, 2009 at 8:44 pmReally? Has that been happening to you? It’s never happened to me.
All the best,
Tom
John Pale
September 15, 2009 at 10:20 pmCheck the pixel aspect ratio in After Effects. I’ll bet for some reason its seeing it as square pixels.
Use the “Interpret Footage” dialog to fix that.
