FCP 7 – ProRez 422, Audio Fine, Video Too Long & Cutting Off
Hi All!
First timer here, so please be patient. I’ve heard good things.
So I’m working on a project with Final Cut 7 on OSX. All my .mov files are encoded with 422, as to keep a consistent workflow environment. I went to begin constructing the film, dragging in my “Intro” edit. The clip is 5:37 long. I noticed the audio is the correct length. The clip is indeed 5:37. BUT the image must be running at a slow frame rate because it cuts out as if the clip ended at 5:00. If there were dialog (there isn’t) I’m sure the talking would be out of sync. Meaning the time the image is on screen has been stretched somehow. If I open in Quicktime or VLC or Preview, the correct playback occurs. But FINAL CUT causes this problem.
Any ideas? I’m guessing something with the source-footage being encoded through 422?
