FCP 7 pixel aspect ratio sequence setting problem – different size pictures in same sequence????
HELP!!!!!
A project I am currently working on has video clips which have come out three different size/shapes. Is this a pixel aspect ratio problem, as they were all filmed using the same camera settings? They were filmed in 1080p, FXP, with a 24p frame rate on a Canon XA10. I have set the sequence settings to:
frame size: 1440×1080
pixel aspect ratio: HD (1140×1080)
editing timebase: 23.98
compressor: XDCAM HD 24p (35mps)At the moment some of the video appears stretched. If i change the pixel aspect ratio to square, it mostly seems in proportion but still three different sizes. Also some of the video clips fill the canvas screen while others have a black border all around (widescreen??)
How do I fix this problem without having to start the editing process all over again???
Adi
